Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case CC high engine oil pressure
Christopher Mikesell
01-26-2013 20:05:27
Personally, I would go looking for a different oil pump. It is always possible that someone adapted a pump from another engine that had the pressure relief valve located in a different place. It takes torque to make that much pressure, which is probably hard on the pump drive gear on your camshaft, as well as on the pump itself. The last thing that you need is for somthing to fail and the oil pressure to drop to zero while you are running the tractor. Also, make sure that your gauge is accurate, and is calibrated in psi, not kpa (125 kpa = 18.1 psi).
01-26-2013 20:22:45
 Re: Case CC high engine oil pressure in reply to Christopher Mikesell, 01-26-2013 20:05:27
Sorry about the pressure comment, I just re-read your first post and noticed that you already checked with multiple gauges.
