case 1845 c freeze plug block heater
I am having a HUGE problem removing the freeze plug block heater on my cummins 4bt. I have tried using a 2 lb slide hammer a crowbar behind the slide hammer jaws and pulling. This thing will not budge an inch. I am past the point of leaving it there. I had to drill the center of it out. Any idea is welcome at this point.
Got it today. Had to drill to 3/4" and used a pilot hearing puller. Someone installed with indian head gasket sealer. I figured they did since I could see it on the block. Thanks jon
