| Case Tractors Discussion Forum |
Topic: Case CC high engine oil pressure
[Return to Forum]
| Author |
[Modern View]
| basil greenleaf
01-26-2013 07:56:12
184.63.230.151
Has any one had an experience with a Case CC high engine oil pressure? If so what can correct it? I cannot find a relief valve anywhere in the engine. My CC engine oil pressure is 125 PSI (checked several times) with different gauges. I"m afraid to drive it. I have removed the oil pump several times and it looks original. Two small gears. Thanks for any info you can provide. Basil |
| Christopher Mikesell
01-26-2013 13:04:24
76.226.219.43
Re: Case CC high engine oil pressure in reply to basil greenleaf, 01-26-2013 07:56:12
| I had a problem with high oil pressure in my SC this past summer. The pressure relief valve was stuck closed and the oil pressure gauge pegged. It was a 60 psi gauge. I checked my IT manual and it said that the pressure relief valve was contained within the oil pump casting on all C tractors. The illustration in the manual showed a large hex bolt on the side of the casting. This bolt held a spring and plunger within the pump body. However, the text said that there were two types of relief valves, the older one (before SN 4209666) was an adjustable ball type, and the newer one was the non-adjustable plunger type as shown in the illustration. Thus, the illustration might not match what you have. The proper oil pressure should be 30-35 psi. I doubt that your oil pressure would get that high unless your pressure relief valve is stuck or blocked. |
| basil greenleaf
01-26-2013 14:24:36
184.63.230.151
Re: Case CC high engine oil pressure in reply to Christopher Mikesell, 01-26-2013 13:04:24
| My CC has a plunger type oil PSI gauge on the block. It pops all the way out to show I have oil pressure. I have taken this pop out plunger apart several times. No relief valve on it. The pump consists of two small gears with no casting holes or other means of relief. And for the life of me I cannot find a oil pressure relief valve anywhere in the system. Thanks for the info. Basil |
| dboll
01-26-2013 14:47:00
209.23.168.152
Re: Case CC high engine oil pressure in reply to basil greenleaf, 01-26-2013 14:24:36
| that's the oil pressure indicator not the system relief, relief valve is located in the pump body and adjustable on all of the C series except the late ones and should be set for 30-35psi |
| basil greenleaf
01-26-2013 18:57:24
184.63.230.151
Re: Case CC high engine oil pressure in reply to dboll, 01-26-2013 14:47:00
| I have dropped the engine oil pan and took the pump out several times and cannot find a relief valve anywhere on the pump body. When I remove the cover there are two small gears (aprox. 1" in diameter)in the body but nothing else. Thanks for your info. Basil |
| dboll
01-27-2013 06:42:55
209.23.168.85
Re: Case CC high engine oil pressure in reply to basil greenleaf, 01-26-2013 18:57:24
| it should be in the T shapped fitting screwed into the pump body which the oil line attaches to, if it's not there someone deleted it |
01-26-2013 20:05:27
76.226.219.43
| Personally, I would go looking for a different oil pump. It is always possible that someone adapted a pump from another engine that had the pressure relief valve located in a different place. It takes torque to make that much pressure, which is probably hard on the pump drive gear on your camshaft, as well as on the pump itself. The last thing that you need is for somthing to fail and the oil pressure to drop to zero while you are running the tractor. Also, make sure that your gauge is accurate, and is calibrated in psi, not kpa (125 kpa = 18.1 psi). |
01-26-2013 20:22:45
76.226.219.43
Re: Case CC high engine oil pressure in reply to Christopher Mikesell, 01-26-2013 20:05:27
| Sorry about the pressure comment, I just re-read your first post and noticed that you already checked with multiple gauges. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
