Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Bits and Pieces
Tom (Kansas)
01-24-2013 17:41:23
I don't know how many Deere reman engines I installed, but the only one that came back so far was a 404 I put in a 4020. The original engine had a loose rod and the reman came back one year later with a loose rod too. The biggest problem we have with them (reman select) are the injection pumps.
01-25-2013 07:42:29
 Re: Bits and Pieces in reply to Tom (Kansas), 01-24-2013 17:41:23
Again, quoting my Diesel shop, Reman Select use re-chromed plungers/barrels in their inline pumps.
Agri King
01-25-2013 05:03:01
Tom the owner of this 4640 says the reman engine seems to lack bottom end power, compared to the worn out original engine. I remember seeing the dyno sheet that came with the engine and that looked fine. What injector pump problems have you seen?
Tom (Kansas)
01-25-2013 18:10:28
 Re: Bits and Pieces in reply to Agri King, 01-25-2013 05:03:01
I put one on a 4wd that would not time up where it should have. I jumped a tooth on the camshaft and got it timed up but the engine would smoke like a frieght train but would not run. A reman engine in a 4850 was hard to start. It would start fine if the engine was warm but would crank over a lot to get running if it was below 60. Another guy installed one that had a crack in the housing and leaked fuel out. He replaced that one with one that the governor would let it run wild. He replaced that one with a third pump and it worked good. I have heard some of our customers thought the low end power was not there, but I figured it might just be a new engine and not broke-in yet.
