Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
SC Footclutch Lining Thickness?
Christopher Mikesell
01-23-2013 20:25:52
I just pulled the crankshaft out of my 54' SC and would like to know the thickness of the lining on a new clutch disc. I only drove the tractor a small ammount before tearing it down and never put it under a significant load. Thus, I don't know the condition of the clutch. I would like to estimate how much wear is left in the clutch when I disassemble it to remove the flywheel from the crankshaft tomorrow.
L.LAMP
01-24-2013 19:23:10
 Re: SC Footclutch Lining Thickness? in reply to Christopher Mikesell, 01-23-2013 20:25:52
CHECK TO SEE THAT YOU HAVE ALL THE SPRINGS IN THE PRESSURE PLATE. CONSULT LATE MODEL SERVICE MANUAL.
Glenn F.
01-24-2013 19:10:53
Measure any new clutch of about that size. I expect they're all pretty close.
Glenn
rustred
01-24-2013 07:16:05
i would call it good if you have about 1/8" above rivets. if lining is getting close to rivets time for reline or replacement, check springs and spline also.
01-24-2013 19:31:46
 Re: SC Footclutch Lining Thickness? in reply to rustred, 01-24-2013 07:16:05
The thickness of the lining is about 5/32" on each side of the plate, and the height above the rivets is 3/32". The facings on the flywheel and pressure plate look good, and the splines look good too.
