Puzzling question brought forward.
Adirondack case guy
Back a bit there was a post about a 200B Utility, with Case built Utility loader. The exaust came threw the hood. I asked at the time if Case had a different manifold and hood for these tractors.
Well today I was looking through an op. manual for the Case model 291B loader, trying to determin the loader model on Bruce's newly aquired 830 standard tractor, and ran across this in the manual Form #9-136-1.
As I looked at it I said to myself there is your answer. Well it raised more questions, rather than answering them. I read it through and was thinking that 300s-600s don't have a port on the manifold to mount a "pipe" refered to in the text. Both my 300RN and 511B have the front side outlet port and the rear down port for underneith exaust, BUT no top front port, like on my 430s, which don't have the side port. You older Case guys are going to have to explain this situation to me. We never cut holes in hoods to mount loaders and sold manny a small frame tractor with Case loaders.
So my lingering questions are
(1) does anyone have a parts breakdown showing the "pipe" procured from Case parts, to route the exaust threw the hood?
(2) how would it fasten to the existing manifold, as there is no top front port and very limited room for a reconfigured cast elbow.
(3) What did they use for measurments on the RN 300 and 350
Loren
Perhaps you take the manifold off and turn it over. Seems my VA manifold would work that way, just a guess,Iam not looking at it just remebering it to be difrent than the manifold on the 430 I had. Those under slung muffeles were great for setting a widrow of hay on fire, when you were raking.
Since I'd seen that thread on the 200b it's made me wonder if my 1957 320 with factory loader came through the hood or not. Next time I'm over at my brother's I'm going to check and I will take pictures of the manifold if it does.
Completely different engine and manifold that exhausts on the right side of the head instead of the left side, if I'm not mistaken. Good thought though.....
Loren, good info from Case BUT whoever thought this up did not allow enough clearance between the hole and the exhaust pipe that comes from the bottom of the muffler. The hole in my 630 hood is about 3 1/2". If insufficient clearance is allowed the exhaust heat will burn the paint off the hood around the exhaust pipe. Otherwise this looks like a good idea and when the 30 series came out the general purpose hood was punched for muffler penetration.
Jim
Jim,
These tractors had a much smaller Dia. muffler. If they cast an elbow that bolted to the side of the manifold and tucked back under the hood, to exit in that hole, burnt paint certainly would be an issue. There is a 320 near me, and tomarrow I hope to get a hands on look at the exaust system. This tractor has the muffler over the hood, not beside it.
Loren
