Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 210B hood.
Case Nutty 1660
01-23-2013 15:10:15
a 430 hood I think is the same except it the 200B does not have a hole for the exhaust
Joe Young
01-23-2013 15:44:56
 Re: 210B hood. in reply to Case Nutty 1660, 01-23-2013 15:10:15
Tom
I think you're half right.... The hood from a 430 spark ignition should fit, and one with an underneath muffler system would not have the exhaust hole knocked out....
The diesel tractors would have a hood about 1 1/2 inches too long for the 200B application. - Joe
Bruce from Can.
01-23-2013 17:22:35
 Re: 210B hood. in reply to Joe Young, 01-23-2013 15:44:56
Why is the diesel 430's hood longer than the gas model?
Joe Young
01-23-2013 17:26:41
 Re: 210B hood. in reply to Bruce from Can., 01-23-2013 17:22:35
The 188 diesel engine block is approximately 1 1/2" longer than the 126 148, 159 and 164 cu in gas engine blocks.
Case Nutty 1660
01-23-2013 15:49:22
YES you are right Joe spark only thanks cnt
Jeremy Shadwick
01-23-2013 16:41:40
 Re: 210B hood. in reply to Case Nutty 1660, 01-23-2013 15:49:22
good deal, thanks for the info. This is a tractor i have recently purchased and its been pretty good so far. I still need to do a 12v conversion, i was wondering if this can be done with the generator or do i have to get an alternator? I also need to get the lift cylinders rebuilt for my loader and my control valve is leaking pretty bad. I got some work cut out for me but it will be a good project.
Stephen Newell
01-23-2013 20:20:14
 Re: 210B hood. in reply to Jeremy Shadwick, 01-23-2013 16:41:40
With a 12v conversion you would need a alternator and also a coil resister between the power supply and the coil.
Joe Young
01-24-2013 03:58:08
 Re: 210B hood. in reply to Stephen Newell, 01-23-2013 20:20:14
Why do you need an alternator for a 12 volt conversion? There are plenty of 12 volt systems with a generator.
