I posted once before but still can not find part number for seals in a valve that raises and lowers box blade. g430 Ser # 8197258. I have talked to 3 Case IH dealers one is an old Case dealer. Also talked to 2 industrial dealers and looked on websites with no success. I called hydraulic dealers. They say I have to go thru Case. The shaft mics at 1 in and the seals are .135 wide. I have O-rings but I think they will scar when the shaft is pushed thru.It is hard to push and the corners are sharp.
I believe this is a factory set up. Thanks
