Gerald E Ackerman, Sr.
New User
Case upgraded the installation of the pinion shaft with the following heavier duty parts:
V-202203, Washer-Thrust gear spacer (2-1/2" OD dia, 0.1345" thick)
V-20217, Washer-Spring tension (0.080" thick)
V-20218, Washer- Thrust (1-5/8" OD dia., 0.164"-0.170" thick)
V-21042, Spacer-1st and 2nd gears (2-1/4" OD dia., 1.300"-1.306" in length)
Does any one have these parts or know where to get these parts? They were included in a Spring washer and spacer kit, VTA-1649.
Gerry A.
Gerry A.
