| Case Tractors Discussion Forum |
Topic: Re: 630
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| 1031D
01-21-2013 08:40:59
107.8.250.69
Biggest thing with carbs is they need to be clean and tight. This garbage gas we have makes matters worse because letting them sit a couple months can gum them up, then if you have an aluminum carb it will eat the metal. I just did a VAC TSX114 and the idle circuit was clogged solid with what looked like pine sap. I agree that most of the exchanged rebuilds are fairly poor, had a customer put one on his Allis, followed by a brand new aluminum Zenith/Bendix and after the fuel ate it I rebuilt the rebuilt carb and it's been running fine since. The throttle shaft needs to be tight, sloppy clearances allow dirt in and lower the manifold vacuum. Same with needles, if they're loose or grooved it's real hard to get them to meter right. I just finished an article for OAN on this for the spring issue. Most people think rebuilding a carb involves splitting the halves, cleaning the bowl, replacing the float valve and bowl gasket, but they often forget about the 2-3 brass orifice plugs for the idle and load circuits, or to remove the main nozzle and make sure the holes are opened. When I do a carb I strip it down as far as I can, then it goes into a 180* wash cabinet. After that, if things still won't move I throw it in the oven at 450* for an hour. You would be amazed at all the junk you find hidden in the passages. After it's stripped down to the bare castings I fish all the holes out with a piece of welding wire followed by a pin tip high pressure blow gun and some carb cleaner. You have to make sure all the gasket surfaces are FLAT as many bowls are subject to overtightening and warp as does the intake mounting flange. I have yet to give up on a carb, especially a Marvel Schebler. Rebuilding a carburetor is getting to be a lost art.
This post was edited by 1031D at 08:41:34 01/21/13. |
| caseanonymous
01-21-2013 11:46:37
75.249.55.192
Re: 630 in reply to 1031D, 01-21-2013 08:40:59
| Thanks for the rebuilding advice. I might try doing it again but the mounting flange is cracked on this unit and I cant get it to seal to the manifold at all. Looks like i'll try the combine carb. I was able to price new ones joe but the ones I can find are in the 325 to 400 dollar range, but havent priced one strait thru zenith. In your guys opinion which make of carbeurator is better? |
| Joe Young
01-21-2013 11:50:29
75.92.245.199
Re: 630 in reply to caseanonymous, 01-21-2013 11:46:37
| You're not looking hard enough at $325-400. My email is open. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
