TractorLinks.com
Show Parts for Model:
Re: SC-DC questions
Christopher Mikesell
01-19-2013 12:50:26
First, there is probably nothing wrong with your clutches. The engine constantly pumps a stream of oil into the center of the clutch assembly, which lubicates it. This oil also causes a drag force which causes the belt pulley to spin with the clutch disengaged and the transmission in neutral. That is why there is a brake pad that rubs on the belt pulley.
Second, there is not supposed to be a weap hole in the governor casting. There is a weap hole in the back side of the magneto casting. If it is leaking out of the magneto casting, then you will need to remove the magneto and governor assembly, disassemble the givernor assembly, and replace the bad seal (which is in the governor casting).
Third, the hydraulic swivels are prone to leaking. I would suggest that you remove the fitting and clean it thouroughly, and make sure that the gasket is present. Sometimes the seating surfaces get rusty and pitted. If they are bad, then you can just braze the swivel solid. You could also look for a replacement fitting from a parts tractor.
