Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 400 super diesel
Don Rudolph
01-17-2013 10:07:24
There are a couple of things different on a Super. As Tom said a Super will have a PTO brake and also on the steering column there is a "boss" for the eventual Case-O-Matic lever on the 800. It is on the left side of the casting and is a flat spot that would be drilled and threaded if the column was used for COM. On the Super it is not drilled or threaded, but you can see how it would work. Also the block for a Super should be A1111, the same as a 700 or 800. I also believe the pump is set at 100 RPM higher than a regular 400. I need the experts to wheigh in on that. In addition the tool box is much bigger and does NOT have CASE stamped into the cover. That should give you enough clues to go by. I hope you have found one! Don
01-17-2013 10:18:07
 Re: 400 super diesel in reply to Don Rudolph, 01-17-2013 10:07:24
Also, the sides of the grill are cut out for the cultivator stay rod mounts to bolt on.
