630 bearings
case1570
Does anyone know if part #A36450 main bearings are standard or oversized It is hard to mic them without removing the crank and I want to get parts ordered. CNH does not offer info any more.
Thanks!
Brian
CASE put the individual part number of the 1/2 shell on each 1/2. But, the part number in the book is for the 2-1/2's in 1 box. A different number.
Seems to make sense. In the oilfield maunufacturing business I once worked in we used an alpha character in our system so indicate a sub assembly of parts that had their own individual part numbers, even when they were welded together and were not field serviceable as parts.
Bet you couldn't buy a bearing half if you wanted to and it would be the same dimensions as another one of the same number from another box anyway due to manufacturing tolerances.
Jim
