Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Transmission Tester with Picture
[Show Entire Topic]  [Return to Forum]
Ande
01-16-2013 06:08:05
66.231.103.186
Rod,I knew Mark Huemanen,he was our territory man,for a few years,and he ended up in Racine,the last I saw him.Was good to us.
[Reply]   [No Email]
1370rod
01-16-2013 10:33:52
174.125.224.243
 Re: Transmission Tester with Picture in reply to Ande, 01-16-2013 06:08:05
Mark was a wonderful guy, to good to be out in the country so thats why CASE moved him to Racine. When the first 2470's were gear jumpers, he tore one down for us while I just assisted to show how to repair the problem. The job sucked and he was not afraid to get dirty, always admired him for that. Rod.
[Reply]  [No Email]
casecollectorsc
01-16-2013 14:46:35
75.102.168.18
 Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 10:33:52
Just curious, what was the cause of the gear jumping? Couple years ago I put a new cable on 1st and 2nd gear. Moves so easy it about falls out of 2nd and will come out under load after about 45 minutes use. Acts more like the spring on the detent is very weak, but would like to know if more serious. This on a very early 2470.
[Reply]  [No Email]
1370rod
01-16-2013 17:43:18
174.125.224.243
 Re: Transmission Tester with Picture in reply to casecollectorsc, 01-16-2013 14:46:35
Their theory at the time was to much gear endplay on the output shaft. What we did then to correct it was replace both driver and driven gears, add shims to lessen gear endplay. We had only a few that had this problem occured on, for the most part the later white 24's never bothered. When the 90's came out CASE added hyd pressure to the detents and changed the teeth on the hub that the shift collar engages to hold it from slipping out. The older ones have the same shift fork detent set-up as the 1370,s where it is easy to install new springs, I think on the 24,s that shiftfork cover is covered up by the main side frame which would make that job almost impossible without tranny removal. If yours only comes out of gear after that long of time I would not be too concerned. However it is not good to let them do that, it seem like if they are left to continue doing so they create a wear pattern and the jumping out slowly gets worse. Maybe a light spring could be added to keep the weight of the lever from trying shift it out or every so often just moving the lever to make sure it is still fully engaged. Hope this helps, Rod.
[Reply]  [No Email]
casecollectorsc
01-16-2013 20:23:12
75.102.174.227
 Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 17:43:18
I will admit to using a tarp strap when using 2nd. Most all tillage is done in 3-2. Never had the problem with the old shift cable as it moved quite hard.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
