TractorLinks.com
Show Parts for Model:
Re: Transmission Tester with Picture
1370rod
01-16-2013 06:02:48
Hey Nutty, did you know fella's named Mark Henamen and Jerry Sweeney? Both were Reps when I got into this bussiness. Both hated the damn Bliney Box as they called it. They would adjust a tractor and two hrs later if the unit ether warmed up more or cooled down they found out it was out of adjustment again! Thats when they told us how to adjust without it, although they still had to demo the Box as CASE had told them. Ahhhh.... the good ole days, LOL, Rod.
Case Nutty 1660
01-16-2013 06:16:01
 Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 06:02:48
Rod, Jerry sounds familar but can not place him, the name of the guy who was the "70" series guro that called on us I can not think of his name but I think he was involved heavy into the design of them, my fav rep was Harvey Frick, what a great wealth of Case knowlage he had, he was a good friend and could take a joke well also, sure wish I would have had a video unit back them and would have spent a couple days recording him here I go again reliving the old days cnt
1370rod
01-16-2013 10:37:34
 Re: Transmission Tester with Picture in reply to Case Nutty 1660, 01-16-2013 06:16:01
Jerry lived in E central SD, did work for JD before coming to CASE, just thought maybe he got out your way. Rod.
Ande
01-16-2013 06:08:05
Rod,I knew Mark Huemanen,he was our territory man,for a few years,and he ended up in Racine,the last I saw him.Was good to us.
1370rod
01-16-2013 10:33:52
 Re: Transmission Tester with Picture in reply to Ande, 01-16-2013 06:08:05
Mark was a wonderful guy, to good to be out in the country so thats why CASE moved him to Racine. When the first 2470's were gear jumpers, he tore one down for us while I just assisted to show how to repair the problem. The job sucked and he was not afraid to get dirty, always admired him for that. Rod.
casecollectorsc
01-16-2013 14:46:35
 Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 10:33:52
Just curious, what was the cause of the gear jumping? Couple years ago I put a new cable on 1st and 2nd gear. Moves so easy it about falls out of 2nd and will come out under load after about 45 minutes use. Acts more like the spring on the detent is very weak, but would like to know if more serious. This on a very early 2470.
1370rod
01-16-2013 17:43:18
 Re: Transmission Tester with Picture in reply to casecollectorsc, 01-16-2013 14:46:35
Their theory at the time was to much gear endplay on the output shaft. What we did then to correct it was replace both driver and driven gears, add shims to lessen gear endplay. We had only a few that had this problem occured on, for the most part the later white 24's never bothered. When the 90's came out CASE added hyd pressure to the detents and changed the teeth on the hub that the shift collar engages to hold it from slipping out. The older ones have the same shift fork detent set-up as the 1370,s where it is easy to install new springs, I think on the 24,s that shiftfork cover is covered up by the main side frame which would make that job almost impossible without tranny removal. If yours only comes out of gear after that long of time I would not be too concerned. However it is not good to let them do that, it seem like if they are left to continue doing so they create a wear pattern and the jumping out slowly gets worse. Maybe a light spring could be added to keep the weight of the lever from trying shift it out or every so often just moving the lever to make sure it is still fully engaged. Hope this helps, Rod.
casecollectorsc
01-16-2013 20:23:12
 Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 17:43:18
I will admit to using a tarp strap when using 2nd. Most all tillage is done in 3-2. Never had the problem with the old shift cable as it moved quite hard.
