Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Transmission Tester with Picture
[Show Entire Topic]  [Return to Forum]
Case Nutty 1660
01-16-2013 04:17:40
75.127.24.27
Rod, I always wanted to have one for the shelf also as ours burnt up in our shop fire in 72, I used it on every 70 series we sold up to that point on the 200 hr "after-delivery" check-up we did, after the one burnt up and we were trying to recoup some of the losses we learded on own how to set them by ear like you said and decided we did not need one after all and like you said the "Blinky Box" was history LOL,,,,, fellow Blinky Box user LOL
[Reply]   [No Email]
mEl
01-16-2013 04:41:21
141.151.107.238
Re: Transmission Tester with Picture in reply to Case Nutty 1660, 01-16-2013 04:17:40
We still have ours and have used it many times. It is very sensitive to oil temp changes and if the oil is not brought to temp can cause tight overlaps that will cause the trans momentatily lock up stopping the tractor wheels sliding when the trans is backshifted by clutch pedal depresssion. I'm like the rest now, experience and your senses are your best tool.
mEl
  [Reply]  [No Email]
Case Nutty 1660
01-16-2013 04:57:17
75.127.24.27
Re: Transmission Tester with Picture in reply to mEl, 01-16-2013 04:41:21
mEl I agree with you on the oil temp, we found out real early to hook them to the dyno and run them under load for 20 min or so to try for a uniform trans oil temp that seemed to get a better set on the screws/shift, always seemed like one guy would not be happy enough so we would go out when he was running in the field and do a feel test till he was happy, thats where we started to learn the box was not the best way to go, our service rep was a believer in the box and could set one with it darn good but I think he had more time using one than we could ever get with the numbers of tractors we sold, after the 200 hr service I hardly ever reset one except for a rebuild and that was 20 years later on the norm or more,,,, sorry I am ramble'in about the past way too much
  [Reply]  [No Email]
1370rod
01-16-2013 06:02:48
174.125.224.243
Re: Transmission Tester with Picture in reply to Case Nutty 1660, 01-16-2013 04:57:17
Hey Nutty, did you know fella's named Mark Henamen and Jerry Sweeney? Both were Reps when I got into this bussiness. Both hated the damn Bliney Box as they called it. They would adjust a tractor and two hrs later if the unit ether warmed up more or cooled down they found out it was out of adjustment again! Thats when they told us how to adjust without it, although they still had to demo the Box as CASE had told them. Ahhhh.... the good ole days, LOL, Rod.
  [Reply]  [No Email]
Case Nutty 1660
01-16-2013 06:16:01
75.127.24.27
Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 06:02:48
Rod, Jerry sounds familar but can not place him, the name of the guy who was the "70" series guro that called on us I can not think of his name but I think he was involved heavy into the design of them, my fav rep was Harvey Frick, what a great wealth of Case knowlage he had, he was a good friend and could take a joke well also, sure wish I would have had a video unit back them and would have spent a couple days recording him here I go again reliving the old days cnt
  [Reply]  [No Email]
1370rod
01-16-2013 10:37:34
174.125.224.243
Re: Transmission Tester with Picture in reply to Case Nutty 1660, 01-16-2013 06:16:01
Jerry lived in E central SD, did work for JD before coming to CASE, just thought maybe he got out your way. Rod.
  [Reply]  [No Email]
Ande
01-16-2013 06:08:05
66.231.103.186
Rod,I knew Mark Huemanen,he was our territory man,for a few years,and he ended up in Racine,the last I saw him.Was good to us.
  [Reply]  [No Email]
1370rod
01-16-2013 10:33:52
174.125.224.243
Re: Transmission Tester with Picture in reply to Ande, 01-16-2013 06:08:05
Mark was a wonderful guy, to good to be out in the country so thats why CASE moved him to Racine. When the first 2470's were gear jumpers, he tore one down for us while I just assisted to show how to repair the problem. The job sucked and he was not afraid to get dirty, always admired him for that. Rod.
  [Reply]  [No Email]
casecollectorsc
01-16-2013 14:46:35
75.102.168.18
Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 10:33:52
Just curious, what was the cause of the gear jumping? Couple years ago I put a new cable on 1st and 2nd gear. Moves so easy it about falls out of 2nd and will come out under load after about 45 minutes use. Acts more like the spring on the detent is very weak, but would like to know if more serious. This on a very early 2470.
  [Reply]  [No Email]
1370rod
01-16-2013 17:43:18
174.125.224.243
Re: Transmission Tester with Picture in reply to casecollectorsc, 01-16-2013 14:46:35
Their theory at the time was to much gear endplay on the output shaft. What we did then to correct it was replace both driver and driven gears, add shims to lessen gear endplay. We had only a few that had this problem occured on, for the most part the later white 24's never bothered. When the 90's came out CASE added hyd pressure to the detents and changed the teeth on the hub that the shift collar engages to hold it from slipping out. The older ones have the same shift fork detent set-up as the 1370,s where it is easy to install new springs, I think on the 24,s that shiftfork cover is covered up by the main side frame which would make that job almost impossible without tranny removal. If yours only comes out of gear after that long of time I would not be too concerned. However it is not good to let them do that, it seem like if they are left to continue doing so they create a wear pattern and the jumping out slowly gets worse. Maybe a light spring could be added to keep the weight of the lever from trying shift it out or every so often just moving the lever to make sure it is still fully engaged. Hope this helps, Rod.
  [Reply]  [No Email]
casecollectorsc
01-16-2013 20:23:12
75.102.174.227
Re: Transmission Tester with Picture in reply to 1370rod, 01-16-2013 17:43:18
I will admit to using a tarp strap when using 2nd. Most all tillage is done in 3-2. Never had the problem with the old shift cable as it moved quite hard.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
