TractorLinks.com
Show Parts for Model:
Re: 411B-turn key to start and not even a click
vqarabs
01-15-2013 18:35:00
I cleaned off battery posts, solenoid posts, start post. Battery sitting at 12.8V. Loosened up starter to make sure it wasn"t locked up on flywheel, and also ran wire direct from battery to starter. Would get a little spark from battery to solenoid or from battery to starter. Could hear solenoid click a couple times when turning the key, but then try it again and nothing. Like it"s grounding out. Thinking bad solenoid and/or bad starter. Unless I"m missing something else?
Jgarner
01-16-2013 07:39:19
 Re: 411B-turn key to start and not even a click in reply to vqarabs, 01-15-2013 18:35:00
Takes a little work but did you pull the starter and do a bench test to see if it turns under no load and the Bendix works? That could help narrow it down.
Jim
vqarabs
01-17-2013 14:53:33
 Re: 411B-turn key to start and not even a click in reply to Jgarner, 01-16-2013 07:39:19
I did pull the starter and applied power to it - it's spinning.....also double-checked voltage readings at battery posts - 12.48, then put battery clamps back on and checked voltage at coil and starter ground - 12.45.
