Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: More problems with Case CK 830
John Saeli
01-15-2013 17:19:55
That piece you have unbolted is a "seal carrier". It can be difficult to remove. There is an o ring behind it. The seal can be removed by stabbing it & prying it out. The reason you can't turn the shaft is because when not in use, there is a brake applied to keep the shaft from turning. Or, worse case, the brake is wore out, & the plates are warped.
denverslim
01-15-2013 17:22:09
 Re: More problems with Case CK 830 in reply to John Saeli, 01-15-2013 17:19:55
John, the little oil seal that is leaking around the shaft--can I just pry it out from the outside, destroying it, and then replace it?...slim
denverslim
01-16-2013 07:38:52
 Re: More problems with Case CK 830 in reply to denverslim, 01-15-2013 17:22:09
Thanks, Fellas.
Austin, do you remember where you got the new oil seal replacement. I'm getting quite an inventory from the catalogs of wrong sizes. I removed the one from the tractor and I'm sizing it and trying to replace it. I've finally broken down and ordered a parts manual to help me thru some of these messes I get into...slim
Case-O-Man
01-16-2013 12:01:43
 Re: More problems with Case CK 830 in reply to denverslim, 01-16-2013 07:38:52
I ordered mine though case I beleve it was part# H749218 but you might want to double check that. I know it didn't cost over $15.00 Austin
