TractorLinks.com
Show Parts for Model:
Re: 311 questions
Adirondack case guy
01-15-2013 09:20:06
The price seams a bit steep, New Tires could push it up there. You can use any CatI 3pt. implements. The pto has a hand clutch on the left side, if it is a tripple range 12spd trans. If it is only a straight 4spd there is no live pto. To shift the tripple range lever on the right, note the High is straight up, Direct is straight down, but to get to low range you have to go back to nutral and slide the shift lever sidways to the right and then push it forward. The gears are not in a progression from low range one to high range forth. It takes a while to learn what gear and range combination proceeds the next.
Loren
Loren
