| Case Tractors Discussion Forum |
Topic: Case 930 Oil Pressure
[Return to Forum]
| Author |
[Modern View]
| fairchm
01-14-2013 13:26:53
75.148.81.187
I have about 10 hours on my 930 c/k after a complete engine rebuild. All has been fine until I recently noticed that my oil pressure has started fluctuating. Runs about 40psi, then drops to 20 and appears to randomly swing back and forth. I do have some additional potentially useful information.
It has recently dropped below freezing for the first time since I owned the tractor. The oil appears to be clean and free of water. I"ve changed the oil and filter once since the rebuild (15W-40). A new oil pump was not available during the rebuild, so I selected a lightly used unit. Cleaned it , checked clearances. Never seen like before. Any one have ideas? |
[Reply] [No Email] | |
| DKase
01-14-2013 20:56:02
75.102.180.184
Re: Case 930 Oil Pressure in reply to fairchm, 01-14-2013 13:26:53
| I have a 54 DC that does that when it is 1 qt low on oil. There must be a leak in the suction line to the oil pump. Possibility if the gauge checks out OK. |
| casecollectorsc
01-14-2013 13:44:07
75.102.174.134
| Are the bearings the same clearance as the crankshaft is ground to? In otherwards a crank ground .020 under needs bearings to correspond. I overhauled a 403 IH combine engine one time and ordered the bearings and put engine together and back on combine and when engine was warm 10# pressure. Take it off and back apart. They had given me std. bearings on a .020 shaft. I learned to check after that. |
| jon f mn
01-14-2013 13:35:06
209.253.26.139
| Did you check your gage? |
| fairchm
01-31-2013 09:23:36
75.148.81.187
Re: Case 930 Oil Pressure in reply to jon f mn, 01-14-2013 13:35:06
| | Thanks everyone for the tips. I purchased an extra gauge and need to hook it up. I'd dismissed the gauge as a possibility as I didn't think a bad gauge could cause such odd behavior. In regards to bearing clearances, I didn't make it clear but the pressure was rock solid at 40 psi for the first 10 hours then suddenly started acting up. Oil pump sucking air is an interesting idea. I don't remember any O-rings or other sealing devices on the oil pump inlet. Need to look at the manual again. Thanks again |
| fairchm
02-01-2013 13:51:15
75.148.81.187
Re: Case 930 Oil Pressure in reply to fairchm, 01-31-2013 09:23:36
| Verified today that the problem is not the oil gauge. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
