TractorLinks.com
Show Parts for Model:
Re: need con rod/870
RGMartin
01-08-2013 15:30:35
Some of the very early diesels used the small wrist pins. I sold a set I had from an 870 gas to a guy who needed them for a early 970 diesel.
870 gas uses a balancer oil pump just like the 267 and 336
Aren't the cams the same? What are you planning on using for heads?
Nedd
01-11-2013 14:36:47
 Re: need con rod/870 in reply to RGMartin, 01-08-2013 15:30:35
I plan on using 970 heads. My VERY early 970 sn number 8650012 had larger wrist pins. I pulled the original rod bearings out dated OCT 69. Just need to find an intake for the 870 diesel. gas cams have a shorter duration from what I have read. Intake is open longer on diesels to max out air into combustion chamber.
RGMartin
01-11-2013 14:53:35
 Re: need con rod/870 in reply to Nedd, 01-11-2013 14:36:47
0012, That is very early... The 870 gas I knocked in the head for parts was in the 100's and I thought it was early.
Count your head bolts. It sticks in my head that the gas had one less bolt.
