Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: VAC-14 shift lever rubber boot
casecollectorsc
01-08-2013 02:40:00
The shift lever is threaded. Take a channel lock pliers and wrap a rag around the pristine knob, grab it with the pliers and remove. Although not original, you can get a boot from Tractor Supply or similiar store to replace boot or knob should it break. The knurled piece you see is what the knob material is attached to.
Loren in MN
01-08-2013 09:45:55
 Re: VAC-14 shift lever rubber boot in reply to casecollectorsc, 01-08-2013 02:40:00
Then as I understand this, the knob has a threaded insert set inside the bakelite that is threaded to the shaft. Would explain why I've seen shift levers in bone yards -both ways.
Thanks much!
Anyone ever heat the lever/shaft below the knob?
Ttim
01-08-2013 10:20:08
 Re: VAC-14 shift lever rubber boot in reply to Loren in MN, 01-08-2013 09:45:55
Try a strap wrench
