Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
CASE RC RING GEAR
RON MAURER
01-07-2013 19:08:15
I'M RESTORING A 1938 RC (CASE) TRACTOR. I PLAN TO INSTALL A STARTER, BATTERY AND RING GEAR. I WOULD LIKE TO PURCHASE A STARTER AND RING GEAR , IF YOU HAVE SAME. A 6 VOLT STARTER IS FINE. THE RING GEAR MUST HAVE 101 TEETH, OUTSIDE DIAMETER APPROX 12 3/4" AND THE INSIDE DIAMETER APPROX 12 1/4".
RON MAURER
01-09-2013 04:27:55
 Re: CASE RC RING GEAR in reply to RON MAURER, 01-07-2013 19:08:15
THANKS FOR THE MANY RESPONSES TO MY RING GEAR PROBLEM. I REMEASURE THE GEAR LAST NIGHT. THE ID IS 11 3/4" NOT 12 1/4". IT IS 12 3/4" OD WITH 101 TEETH. THANKS AGAIN CASE CRAZY!
Eldon (WA)
01-12-2013 12:53:24
 Re: CASE RC RING GEAR in reply to RON MAURER, 01-09-2013 04:27:55
Ron I checked and I have a WD flywheel with a good ring gear on it.....you get to remove it!
Ron Maurer
01-12-2013 16:30:16
 Re: CASE RC RING GEAR in reply to Eldon (WA), 01-12-2013 12:53:24
I'll be in there around 1 P.M. Wed. Maybe I could meet with you on a pass thru. If not then later in week. Ron
Eldon (WA)
01-12-2013 16:43:55
 Re: CASE RC RING GEAR in reply to Ron Maurer, 01-12-2013 16:30:16
I'm usually around...but you may want to call when you know for sure.
RON MAURER
01-12-2013 13:51:59
WOULD YOU ALSO HAVE AN AC MODEL HD STARTER?
Eldon (WA)
01-12-2013 13:55:32
 Re: CASE RC RING GEAR in reply to RON MAURER, 01-12-2013 13:51:59
I'm not sure it will fit, but I do have a WD starter that will need to be rebuilt. I think a fellow commented earlier that you would need a Case starter???
Kly
01-08-2013 07:59:18
so are we talking about a Case tractor or an allis chalmers?
wilson ind
01-08-2013 07:02:12
Pioneer inc automotive products powertrain div also autozone and others have a poineere catalog if you can get them to check bought case ring grears for less than one half cade price fellow at powertrain said they made case ringears for case
jim voyles
01-08-2013 04:12:22
Sorry,WD Allis Chalmers instead of WC.
jim voyles
01-08-2013 04:09:44
Ring gear from a WC Allis Chalmers will fit, starter from SC Case will work.
