Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: need con rod/870
Adirondack case guy
01-07-2013 17:16:22
Rod, I bought and installed several 336T industrial units in 7 and 870 tractors. Case Co.people linked me up with Sandhill Equip. in Bassett NE and I was able to get skid units less sheet metal, drive systems and acessories. All small journal turboed 336s. Bolted them into 7/870 gas chasis and had 100 plus PTO hp tractor.
We also ordered in all the top end parts off these engines and woke up a lot of older 7 and 870s
Loren
Nedd
01-08-2013 15:11:05
 Re: need con rod/870 in reply to Adirondack case guy, 01-07-2013 17:16:22
Can or has anyone converted an 870 gas to a diesel? I am thinking of trying it. I know the top end and cam changes but do the 870 gasers have a balanced oil pump? Just an idea now but might try it.
Also I have an extra set of 870 gas rods but they have a smaller wrist pin than my 970 diesel so i would guess they would not work on an 870 diesel.
RGMartin
01-08-2013 15:30:35
 Re: need con rod/870 in reply to Nedd, 01-08-2013 15:11:05
Some of the very early diesels used the small wrist pins. I sold a set I had from an 870 gas to a guy who needed them for a early 970 diesel.
870 gas uses a balancer oil pump just like the 267 and 336
Aren't the cams the same? What are you planning on using for heads?
Nedd
01-11-2013 14:36:47
 Re: need con rod/870 in reply to RGMartin, 01-08-2013 15:30:35
I plan on using 970 heads. My VERY early 970 sn number 8650012 had larger wrist pins. I pulled the original rod bearings out dated OCT 69. Just need to find an intake for the 870 diesel. gas cams have a shorter duration from what I have read. Intake is open longer on diesels to max out air into combustion chamber.
RGMartin
01-11-2013 14:53:35
 Re: need con rod/870 in reply to Nedd, 01-11-2013 14:36:47
0012, That is very early... The 870 gas I knocked in the head for parts was in the 100's and I thought it was early.
Count your head bolts. It sticks in my head that the gas had one less bolt.
Copyright © 1997-2015 Yesterday's Tractor Co.
