TractorLinks.com
Show Parts for Model:
Re: So I've got this Case 1090...
jon f mn
01-04-2013 07:24:12
his is the first I've seen. I've heard of them tho. What is the difference btween them and the 1070? To bad it's so far away.
Adirondack case guy
01-04-2013 08:16:45
 Re: So I've got this Case 1090... in reply to jon f mn, 01-04-2013 07:24:12
Jon,
The differences are suttle to most people, but quite extensive. There is one that showed up in our area 25 years back, that is still in use, and well cared for.
Here are the differences that I am aware of. Basically Case took bigger ruggeder parts from the 1170 and put them on a 1070.
1) 1170 front axle with external steering cylinders.
2) Heavy duty Fixed arm 3pt, and thick 2 roller drawbar
3) Delta model only, 1170 style disc brakes. ???
4) Cast Iron nose peice
5) Engine side rails and slide out weight frame.
6) not sure, but think they were all 8spds.
7) Both fender stiles available, Cab ???? never saw one with a cab.
Loren
casecollectorsc
01-04-2013 15:30:08
 Re: So I've got this Case 1090... in reply to Adirondack case guy, 01-04-2013 08:16:45
Have you got any leads on the brake discs for a 1170? Got one on the 1170 that is cracked and split open about 1/16". Can't find any here, probably gonna weld it!
Thad
01-04-2013 17:45:10
 Re: So I've got this Case 1090... in reply to casecollectorsc, 01-04-2013 15:30:08
Give me a call in the morning. I think i still have a good one. 417 498 6571 thad
D-C-741
01-04-2013 11:00:52
we Took the motor out of a 1090 at Fred's yard some years back [ it was fire damaged & had Factory Cab & was Power Shift ] I got it from a dealer in PA, who got it in on trade in burned condition.
MOPAR66701
01-04-2013 10:48:02
i had one with a cab. it wasnt a delta it was a western. had a plastic fuel tank.
