Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 580C transmission grease level
Case Nutty 1660
01-04-2013 06:17:18
not sure I would try running it that low, as to the seals my 580CK is at least 5 years older than yours and I have zero seal leaks, when you have replaced seals before did you check the endplay on the carrier assembly? that or damaging the seals on installation should be the only reason they would still leak, unless for some reason the shaft has been damaged/groved ect, I have rebuilt many 580 series brakes/seals and have yet one to leak when I am done, but I have been doing them since 1966 so I do have lots of prior dealings with them,,, as I have said before I always change out the 80wt/90wt with Hy Tran oil and am very happy with how well it works cnt
