I Have a manifold and turbo thats currently on a non running 930. The turbo has only 10 hr on, The manifold is from a 1200 I was told, it is split with turbo mounted in the middle. The tractor is not officialy mine, but if you are interested I could get the details. Rod.
I think that exhaust manifold was also used on early 930's but had another connecting bracket for the actual exhaust pipe. On the 1200's isn't there a plate connecting the two to the turbo. Never looked at them that close but sure looks like the early manifolds. Hopefully I got this picture to load. It is from the photos here on the board. Look at this exhaust. It is centered not up front like the later ones. Rod email is open would like info on the turbo if there are no other takers.
