1200 gets new engine
111
1200 gets new, 1470 driveshaft brake, and late 1370 engine
I agree Doug, That ole 1200 should wake-up and come to live now. Looks like the guys are doing a very nice job. Rod.
That will make a great tractor out of that 1200. Too bad there are so few of these good solid simple tractors left. Excellent work, looks like new.
Thinking of the same thing but have some questions. How well does the top radiator hose line up? Shroud? and did you use the flywheel setup from the 451?
Im going to use a top rad hose from a 1370, I'm pretty sure the shroud with work if not I might just have to modify it a little bit and yes the flywheel and clutch bolt right up.
If you want call or email me, the engine should be going in maybe in the next couple weeks.
Ben
[email protected]
519-818-8217
