* need spects on a 124 engine *
Dutchman
I'm working on my Vaiw , and need to know tourque of engine head bolts .. which one to start with and where to go next ..
Also do you guys put anything on the head gasket ?? or do you leave it ?? it's been a loooong time for me ..
is there anything I should do before I put it together or after { it WOULDN'T be work on again till spring .. } I did make a crank so I can turn it over ...
I think it's a 124 engine ... could be wrong there too ...
THANKS for any help you can give me ...
mark
VA 124 cid cyl head and torque specs. I put the gsk on dry.
Joe
The above torque chart is for the 300 148 cid. This is the VA 124 cid torque chart. The torque values are largely the same for both engines.
Joe
Joe, I hope you saw my post of my 300RN face lift. Finally got-r-done. Thanks. Been a bit conserned about you, as you hadn't posted for a bit. Bro and I discussed that earlier today. Glad you posted.
Loren
Been missing a few days here and there Loren. Haven't had a chance to go back and read the last couple days yet.
I have much of the same problems as Tom's wife although probably not as serious. Had an ablation recently still working on getting the meds right.
Thanks for the concern, both of you.
Joe
Joe, sorry to hear, if you are any thing like Jill the work they did seems to really "tick" off the heart for a while but hang in there it does get better as you say just have to get every thing back in normal rythem, as Bro say's we were "chatt'n" about you and glad to hear you are on the mend take care will keep you in our thoughts cnt
Jill is doing fine now did not mean to imply anthing recent, I just know first hand that it takes time to get the meds right after having that type of work done and that it took her a while to get back in to feeling good, for her it has helped very much and I hope Joe has the same results like he said it takes time cnt
