Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: case 1570 remote pressure
[Return to Forum]
clint goethe
01-02-2013 20:26:11
64.53.104.30
I HAVE A CASE 1570 THAT HAS 2000 PSI AT REMOTES BUT WONT PICK UP THE IMPLEMENT.THE TRACTOR SHIFTS AND PULLS FINE IN ALL THE RANGES AND GEARS IN THE POWERSHIFT.THE PTO WORKS AND ALSO THE 3PH ALSO WORKS AS I HAVE BEEN PULLING A 3PH CHISEL PLOW WITH IT.THE PRESSURE AT THE REMOTES IS 1000 PSI IDLING AND 2000 AT FULL ENGINE RPM.THE PRESUURE ALSO STAYS THE SAME AT REMOTES AS I SHIFT THREW ALL 3 GEAR ON THE TRANS.I THINK I MAY HAVE A PROBLEM ON THE REMOTE HYDRAULIC VALE RELIEF VALVE,I NEED SOME GUIDANCE.THANKS GUYS.I HAVE FLOW FROM REMOTES WHILE RUNNING OIL INTO A BUCKET.PLEADE HRLP ME TAKE A STEP FORWARD
[Reply]   [No Email]
Dave from Eastern Iowa
01-03-2013 19:00:47
184.20.217.51
Re: case 1570 remote pressure in reply to clint goethe, 01-02-2013 20:26:11
Simple test to make sure plumbing is correct. Unpin the cylinder from the implement and make sure you can move it back and forth with the tractor. If you cannot move it with no weight on it, a larger cylinder won't help. Dave
  [Reply]  [No Email]
clint goethe
01-06-2013 19:01:45
64.53.104.30
Re: case 1570 remote pressure in reply to Dave from Eastern Iowa, 01-03-2013 19:00:47
THANKS FOR EVERYONES HELP.I FOUND THE RELIEF VAVLE ON THE REMOTE VALVE ORINGS WERE MISSING.I HAD TO TAKE THE RIGHT TIRE OFF AS THIS TRACTOR HAS THE 30.5-32 TIRES ON IT.I DIDNT HAVE ANY ROOM TO WORK ON IT WITH THE TIRE ON.I WILL UPDATE WITH THE OUTCOME LATER BUT THE HOSES GOING TO THE REMOTES ARE FLEXING AND ENGINE LUGGING DOWN WHEN I OPERATE THE REMOTE LEVER .I THINK I GOT IT FIXED.CLINT
  [Reply]  [No Email]
jon f mn
01-03-2013 15:31:16
70.199.192.206
The hoses on a 1570 should be hooked either both on the right pair or both on the left pair. The 70's from 1170 and down are matched top and bottom, so they are opposite.
  [Reply]  [No Email]
CLINT GOETHE
01-03-2013 08:31:09
161.156.101.6
I HAVE THE HOSES HOOKED UP IN A STAGGERED PATTERN.ONE AND THREE FOR A PAIR.THEN TWO AND FOUR FOR A PAIR.THANKS FOR THE REPLIES
  [Reply]  [No Email]
John Saeli
01-03-2013 09:26:41
66.66.16.240
Re: case 1570 remote pressure in reply to CLINT GOETHE, 01-03-2013 08:31:09
I don't have a 1570 Parts Book, but if it is the same as the 1370, & if I understand correctly, I think the connection is your problem. As best as I can tell, you should be in pairs, starting from the left, 1&2 for a circuit, & 3&4 for a circuit. Please keep us posted.
  [Reply]  [No Email]
mike Fitz
01-03-2013 06:42:46
208.126.1.129
Do you have the hoses hooked up properly? My neighbors 1070 hooks up one hose in each of the pairs of outlets, not both hoses in one "pair" of outlets like IH,JD etc. I don't know if this is how all CASE's work or just something weird on this tractor.
  [Reply]  [No Email]
CLINT GOETHE
01-03-2013 05:53:56
161.156.101.6
I HAVE NEVER USED THE REMOTES BEFORE NOW.I TOOK THE HOSES OFF THE CYLINDER AND THEY FLOW INTO A BUCKET FINE.IM GO TRY A LARGER DIAMETER CYLINDER,THANKS FOR THE REPLIES.
  [Reply]  [No Email]
John Saeli
01-03-2013 06:42:36
66.66.16.240
Re: case 1570 remote pressure in reply to CLINT GOETHE, 01-03-2013 05:53:56
Clint: Is there any chance you are plugged into 2 different circuits?
  [Reply]  [No Email]
DKase
01-03-2013 05:07:28
75.102.180.184
Are your hydraulic couplers locking up and blocking the flow? If you feel the hoses you can tell if there is pressure in the hose. Should be pressure on one hose to lift, and one hose to lower. There should never be high pressure in both hoses.
  [Reply]  [No Email]
01-02-2013 21:11:29
184.20.217.51
I don't have my manual any more or I would tell you what the pressure should be. Has that tractor been used with that implement before? I bought a heavy disk at a sale and my 1370 could not lift it. The previous owner had too small of a diameter cylinder on it. I put a larger cylinder on and it lifted just fine.
  [Reply]  [No Email]
clint goethe
01-02-2013 20:28:13
64.53.104.30
PLEASE EXCUSE MY SPELLING.LOL
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
