TractorLinks.com
Show Parts for Model:
Re: 2090 Pilot Spools
DKase
12-22-2012 19:39:21
I pull them out and polish them up really good with emery cloth. Make sure you clean them up good so the grit from the emery cloth is all cleaned off. I was told by an old Case shop foreman that if the emery cloth trick does not work to get a stainless ball the same size as the bore, weld a bolt onto it for a handle, heat it to just barely glowing red so it expands in size just a little and push it into the bore to expand the hole just a little. The emery cloth took care of mine so I have not had to try the ball trick.
