Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Replacing Engine in 970 Case
[Return to Forum]
william wright
12-20-2012 17:45:20
70.215.67.208
I have a 1370 Case tractor with a bad transmission. Can i take the motor out of it and put it in the 970 without to many modifications? Has anyone tried?
[Reply]   [No Email]
steve il
12-22-2012 04:11:43
50.103.156.178
 Re: Replacing Engine in 970 Case in reply to william wright, 12-20-2012 17:45:20
we have 2 1175s with 2390 and 1570 front halves. ran them 4 years without problems. we dont pull any bigger equip. just faster and easier. i used whole front half for bigger radiator and heavier front end.
[Reply]  [No Email]
JPB 1070
12-21-2012 18:17:21
68.52.92.23
would you want to sell the bad transmission you have? Is it a powershift or an 8 speed? Thanks James
[Reply]  [No Email]
Eagle Doc
12-22-2012 03:47:26
206.71.211.63
 Re: Replacing Engine in 970 Case in reply to JPB 1070, 12-21-2012 18:17:21
I have a 1370 transmission/rear end that I would sell all or part of. Email is open.
[Reply]  [No Email]
JPB 1070
12-21-2012 17:24:59
68.52.92.23
Is it a powershift or a 8 speed?
[Reply]  [No Email]
RGMartin
12-21-2012 07:53:36
173.189.132.104
If you are putting some power out the PTO, or don't weight it down at low speed it may survive.
Weight it down to 15,000, put a set of 20.8-38 radials on it, and try to pull max loads at 3 mph and you are going to have problems.
[Reply]  [No Email]
JW
12-20-2012 19:38:47
174.255.84.2
It'll fit
[Reply]  [No Email]
JW
12-20-2012 19:43:54
75.207.167.54
 Re: Replacing Engine in 970 Case in reply to JW, 12-20-2012 19:38:47
Use the 970 pan, 1370 radiator, 970 flywheel. You have to do some fabricating for the air intake to get it under the hood. Mine has a late 1070 fitler housing. If your 504 is a later one with oilers you'll want to run close to 5 gal of oil. It will put the oil level right at the F in Full on the 970 dipstick. If you use the 13 tin oil pan you will lose the support the 970 pan provides.
[Reply]  [No Email]
Just Thinkin
12-21-2012 05:31:33
74.34.78.50
 Re: Replacing Engine in 970 Case in reply to JW, 12-20-2012 19:43:54
Did you have trouble with the oil pump gear hitting the pan when you put the cast pan on?
We had that problem with a 504 out of a 2670 that we put in an 1170. When we snugged it up we poped an ear off of the timing cover.
1370 may have a different oil pump. If you do not use cast pan side rails would be a good idea
[Reply]  [No Email]
1370rod
12-20-2012 20:50:42
174.125.224.243
That looks very nice, most people would think its factory equipment. Did the exhaust line up with the original muffler hole? Rod.
[Reply]  [No Email]
JW
12-21-2012 06:19:00
75.207.167.54
 Re: Replacing Engine in 970 Case in reply to 1370rod, 12-20-2012 20:50:42
Yes, It has a 1175/early 1370 muffler on it. The newer 13 muffler would sit high enough to clear the hood line if you put it on backwards but it looked too big on there. It was quieter though. We put a 451 bdt in a friends 970 2 or 3 years ago. That turned out well. He uses his pretty hard but hasn't tore anything up yet.
[Reply]  [No Email]
Just Thinkin
12-20-2012 18:38:56
74.34.78.50
Yes you can. May need a different exaust elbow.
Most everything else should be a direct bolt in.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
