| Case Tractors Discussion Forum |
Topic: 1370rod
[Return to Forum]
| Author |
[Modern View]
| t970
12-19-2012 21:19:35
136.1.1.104
Rod I just got a chance to check on the 3pt on the 970 today the valve under the seat is moving, all cables are good, and no pins broken. So where should I look next if I pick up the lift arms it feel like there is no hyd. fluid in the lift cylinder they just free float up and down. |
| t970
12-20-2012 14:45:54
50.96.248.59
Re: 1370rod in reply to t970, 12-19-2012 21:19:35
| Looking at the manual I will need to remove the fuel tank. To access the cover to be able to unhook the draft linkage before the control valve can be removed. |
| DKase
12-20-2012 21:10:34
75.102.180.184
Re: 1370rod in reply to t970, 12-20-2012 14:45:54
| If it was mine I would pull the small side cover off the DOM valve and clean the needle valve that shifts the raising speed before I pulled the entire valve. My guess is that is where you will find the problem. |
| t970
12-21-2012 03:38:00
136.1.1.104
Re: 1370rod in reply to DKase, 12-20-2012 21:10:34
| Thank you for the advice I will try this next hope all of you have a Merry Chirstmas and Happy New Year |
| 1370rod
12-20-2012 16:09:59
174.125.224.243
| No, the fuel tank does not have to be removed to get valve off. The spool sticking out the front of the valve is disconnected from the draft linkage by removing the spring on it, then insert a punch in the hole drilled through the end of the spool. Using the punch as a handle turn the spool counter clockwise to unthread it from the draft linkage in the tractor. After valve is removed take care not to push the linkage in tractor to far rearward, you need that sticking forward so when reinstalling the valve you can get the two parts threaded back together. The valve removal for the first time can seem difficult but it really is'nt, it just takes time and ask questions if you encounter a problem. Rod. |
| 1370rod
12-20-2012 05:50:23
174.125.224.243
| With all those items checking out OK your problem is more than likely a stuck ball or spool in the valve. (your remotes do work properly right?) The valve is located under the operators seat, that and the platform it sits on will have to be removed. A manual explaining its removal, disassembly and cleaning as well as assembly would be helpful for you. Basicly the items in the valve have to all be clean and free moving. Also with the valve removed the oil ports in the housing which the valve sits on can be pressurized with air pressure and the arms should raise. If they don't you have more serious problem inside the tractor. As far as the arms seeming loose when lifted by hand, thats normal.Just a reminder, keep everything very clean when its apart. Rod. |
| 1370rod
12-20-2012 05:59:15
174.125.224.243
Re: 1370rod in reply to 1370rod, 12-20-2012 05:50:23
| DKase brings up a good point, don't mess with adjustments unless the threaded screw in the lowering spool has come loose and thats very unlikely. Rod. |
| DKase
12-20-2012 05:35:57
75.102.180.184
| The piston does not move when you lift the arms. Next place to go is to pull the small cover on the side of the DOM valve that you say moves under the seat. There is a check valve, and 2 needle valves under there. DO NOT mess with the needle valves unless you have a service manual. One of them will need to be cleaned and reset, and the other is the adjustment for the control of the valve. DO NOT mess with this one!!!! I have not been into one for a couple years and do not remember which one is which. I do need to do my 970 before I blow snow again so one of these days I will have the info you need if someone else does not chime in. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
