Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: CFM through a 504?
Lamont
12-19-2012 15:43:53
Any idea what the Volumetric Efficiency, on average, of a diesel of that era would be? Most spark ignition engines were between 0.7 and 0.8. Would a diesel be close to that or better? My thought would be better, but?????
LApuller
12-19-2012 17:14:15
 Re: CFM through a 504? in reply to Lamont, 12-19-2012 15:43:53
You are way off if you think a older tractor motor will flow between 0.7 and 0.8. Actural flows are more like .45 to .55. A diesel is about the same.
Lamont
12-19-2012 18:38:04
 Re: CFM through a 504? in reply to LApuller, 12-19-2012 17:14:15
I don't doubt you are correct, but are you speculating or is this fact?
LApuller
12-20-2012 03:51:22
 Re: CFM through a 504? in reply to Lamont, 12-19-2012 18:38:04
I have REAL air flow numbers from pulling tractors on a dyno. I have tested almost every type of tractor and have two different ways of testing the air flow.
Lamont
12-20-2012 06:29:55
 Re: CFM through a 504? in reply to LApuller, 12-20-2012 03:51:22
Good enough. Have you tested any with turbos on them. If so, what kind of VE do they have? I would think to get good HP results, it would have to be in the 2 to 3 range, BUT that would mean 5 to 6 times the VE of NA engines. Is that possible?
RGMartin
12-20-2012 09:07:25
 Re: CFM through a 504? in reply to Lamont, 12-20-2012 06:29:55
How much boost?
LApuller
12-20-2012 08:31:13
I have dynoed turbo tractors but have never checked the air flow rates.
massey 333
12-19-2012 16:40:54
This may be a stretch,but try Turbo Pre-Cleaners site or the company copying Turbo.one of them had it a few years ago when we were building our 970 up.
