| Case Tractors Discussion Forum |
Topic: Re: SC Case Thermostat placement?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John Saeli
12-19-2012 04:28:56
66.66.16.240
Did you have the belching problem before you tried the T'Stat? The drilled hole is a good idea. |
[Reply] [No Email] | |
| Tomfg
12-19-2012 15:19:02
206.8.13.87
Re: SC Case Thermostat placement? in reply to John Saeli, 12-19-2012 04:28:56
| FYI, I tested out the thermostat in a pan of hot water with a new candy thermometer. It opened at 170 degrees. I figured that was close enough, so I took it out to the garage, drilled two 1/8" holes in it, installed it, and refilled the radiator. I started it up, and ran it at fast idle for 25 minutes, and the temp gauge needle never moved off the bottom peg,(about 135 degrees) until I shut the engine off, and then it went up to about 150 degrees. Maybe this is okay, being it was 30 degrees outside, and the engine was just idling. If I would have been thinking, I would have put the candy thermometer in the radiator while I was running it to compare with the temp gauge. |
| John Saeli
12-20-2012 04:52:53
66.66.16.240
Re: SC Case Thermostat placement? in reply to Tomfg, 12-19-2012 15:19:02
| Is she good this time? No pushing coolant out? I don't test every T'stat, but radomly check some, & have never found a bad one. |
| Tomfg
12-19-2012 06:21:31
206.8.13.87
| Never had any radiator problems with this tractor in the past, but never had a thermostat in it either. After the partial rebuild of the engine, I ran it for half an hour (without) a thermostat, drove it around, etc., with no problems, and the temp gauge needle never moved off the bottom. Will try testing the thermostat in hot water today for starters, and if it works okay, then drill a little hole or two in it to make sure the air gets bled out of the system when I refill with anti-freeze. Thanks. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
