530 Hyraulics
Lazy WP
I am "swapping" out tractors under my #22 loader and backhoe. Originally it had a model 440H, well now its getting a model 540. In the process, the 530 is losing some parts that aren't needed with the hoe. One of them will be the hydraulic set up. Not sure if any of you are needing it, if not it will go back on the 430, and go to the scappers. I guess if any of you need parts off of the 430, you can hollar. It is a dual range, shuttle. The dual range is OUT!! Motor starts good, but blows LOTS of BLUE smoke.
where you at? i have a good duel range standard clutch gear box off of a 540 and a brand new set of tires off a 540. 14.9x24. between the 2 of us we could make that 430 whole. gus in warren pa.
I am in north central Nebraska. I have no idea what any of its worth, other then scrap value on the tractor is about $200. I can keep it around here if any of you guys east of me are going out to Gillette next summer.
I don't think the 430 is worth putting back into 1 piece.
