MrJDMan80
The neighbor has a 2390 that he picked up at auction. He knows I worked at a caseih dealer and have had a number of powershifts apart. He called tonight with a problem I have never run into before. When the tractor sits for longer than a week, the romote hydrolics will not work. The tractor still drives and pto still works. Only the remotes are affected. Before I end up overthere with a valve body in my hand, what should I look for.
Thanks for all your help
Tim
I'm sure that Mel or Rod will be of more help to you than me on this one but it sounds like the low pressure circuit is working fine (powershift, steering, pto) but the High pressure is not compensating and kicking in when the hydraulic outlets used.
