TractorLinks.com
Show Parts for Model:
Re: A4195aa mounted hyd cylinder assembly for Case 400
Roger S
12-03-2012 05:12:43
Chuck: When you disassemble the cylinder, there is a nut that holds the piston on at the bottom of the shaft. The nut has dimples on it. It will act like it is comming off, but it will screw the threads up on the shaft. I would suggest cutting the nut off and getting a new nut to save the shaft. The top yoke is actually threaded on, depending on if it has been welded in place or not, you may be able to unscrew it from the top to replace the seal. Once you take the top plate off there is a snapring to take out and the fitting on the side has to be removed for disassembly. Good luck!
