Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: vac-14 distributor wore out?
[Show Entire Topic]  [Return to Forum]
mattwillson
12-02-2012 17:12:19
74.14.66.89
if you have a metal lathe, just turn down a base on a chrysler electronic unit...I run one on my farmall m and my tow motor. works great
[Reply]   [No Email]
jmducks1
12-02-2012 18:36:44
69.129.14.62
 Re: vac-14 distributor wore out? in reply to mattwillson, 12-02-2012 17:12:19
What model dist. fits into the autolite from a chrysler? What about the length and the end?Does the cap stay the same, what about coil 12v non resistor or what kind? Sound like a great idea.
[Reply]  [No Email]
mEl
12-03-2012 04:07:56
108.10.129.188
 Re: vac-14 distributor wore out? in reply to jmducks1, 12-02-2012 18:36:44
I did the same thing with the Delco mag replacer only I used a 4 cyl Chevette HEI short cap distributor for our puller DC. Turned the base to match the old dist. and slid the drive gear on and with the thin thrust washers off the old distributor the roll pin hole was even right. I did remove the vacuum advance and made the pickup plate stationary and did work on the advance weights to increase the mechanical advance for pulling. Very trouble free distributor.
The old distributor you are using is just fine with the loose shaft if the weights and springs are otherwise good. The loose shaft makes it impossible to hold points adjustment. The pertronics unit uses a magnet ring and pickup module and precise does not matter with this setup, that is one thing attractive about Pertronics. I have used many in stock and performance applications and all work well if the rest of the tractor system is up to par.
For those of you that use MSD boxes for pulling applications the wide cap spacings are almost a necessity as with extreme high compression engines such as we use in pulling the spark will jump from the tower down to the clips holding the cap on. Once this happens the cap is junk. Don't ask me how I know!!
mEl
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
