| Case Tractors Discussion Forum |
Topic: vac-14 distributor wore out?
[Return to Forum]
| Author |
[Modern View]
| jmducks1
12-02-2012 14:19:47
209.94.191.126
Has alot of play in distributor shaft. Are bushings available? Can I avoid this and put electronic ignition in it? Where should I buy it from and how much does it cost? |
[Reply] [No Email] | |
| Jim McVay
12-05-2012 18:52:06
67.238.0.178
Re: vac-14 distributor wore out? in reply to jmducks1, 12-02-2012 14:19:47
| I ran into the same problem. The bushings are not the problem. It is where the top shaft oes into the lower shaft. I found a delco dustributor out of a 600B. That would be my sugestion to do. |
| jmducks1
12-05-2012 18:57:05
69.129.14.62
Re: vac-14 distributor wore out? in reply to Jim McVay, 12-05-2012 18:52:06
| Thanks alot is the 600B a direct fit or does it take some extra work? Cap the same? |
| mEl
12-05-2012 19:24:55
108.10.129.188
Re: vac-14 distributor wore out? in reply to jmducks1, 12-05-2012 18:57:05
| No. the Delco takes a different cap. It is a drop in tho otherwise.
If you're still thinking bout it the Pertronics is listed under VAC parts on this site. upper corner under marketplace, tractor parts. Gotta know the volts and polarity.
mEl |
| jmducks1
12-05-2012 19:55:27
69.129.14.62
Re: vac-14 distributor wore out? in reply to mEl, 12-05-2012 19:24:55
| THanks alot. what is the going price for a 600B dist. Does anyone have one? |
| jmducks1
12-04-2012 17:52:40
69.129.14.62
| Who sells the petronix at the best price and how much? Would electronic help a distributor with a shaft that has some play in it? Tractor runs fine just had to readjust points more often.. |
| mattwillson
12-02-2012 17:12:19
74.14.66.89
| if you have a metal lathe, just turn down a base on a chrysler electronic unit...I run one on my farmall m and my tow motor. works great |
| jmducks1
12-02-2012 18:36:44
69.129.14.62
Re: vac-14 distributor wore out? in reply to mattwillson, 12-02-2012 17:12:19
| What model dist. fits into the autolite from a chrysler? What about the length and the end?Does the cap stay the same, what about coil 12v non resistor or what kind? Sound like a great idea. |
| mEl
12-03-2012 04:07:56
108.10.129.188
Re: vac-14 distributor wore out? in reply to jmducks1, 12-02-2012 18:36:44
| Quoting Removed, click Modern View to see
I did the same thing with the Delco mag replacer only I used a 4 cyl Chevette HEI short cap distributor for our puller DC. Turned the base to match the old dist. and slid the drive gear on and with the thin thrust washers off the old distributor the roll pin hole was even right. I did remove the vacuum advance and made the pickup plate stationary and did work on the advance weights to increase the mechanical advance for pulling. Very trouble free distributor.
The old distributor you are using is just fine with the loose shaft if the weights and springs are otherwise good. The loose shaft makes it impossible to hold points adjustment. The pertronics unit uses a magnet ring and pickup module and precise does not matter with this setup, that is one thing attractive about Pertronics. I have used many in stock and performance applications and all work well if the rest of the tractor system is up to par.
For those of you that use MSD boxes for pulling applications the wide cap spacings are almost a necessity as with extreme high compression engines such as we use in pulling the spark will jump from the tower down to the clips holding the cap on. Once this happens the cap is junk. Don't ask me how I know!!
mEl |
| Jgarner
12-02-2012 15:59:51
70.139.176.83
| | I rebushed a distributor many moons ago so it can be done. As for electronic ignition, you can convert to EI with a Pertronix system but it uses your existing distributor case and you replace points condenser, rotor so that won't help you any if you have shaft. It works well too BTW and is pretty easy to do. Jim |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
