Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case 430, buzzing relay, won't crank.
hondaracer2oo4
12-02-2012 12:37:17
MEl,
This is what I have determined. When I remove the relay from the starter, ground the body of the relay to the frame and push gear selector to start I get 12.54 volts between the starter side of the relay and a ground. When I hook up the starter into the system and put my tester on the starter side of the relay and the other side of the tester to ground I get 0 volts. It would seem to me that the relay will not switch the power if it is underload. It just makes this buzz/click sound.
mEl
12-02-2012 13:09:22
 Re: Case 430, buzzing relay, won't crank. in reply to hondaracer2oo4, 12-02-2012 12:37:17
using your tester, start at the battery post and check each point of connection with the starter buzzing and see where you lose 12V , should be an easy one.
mEl
Copyright © 1997-2015 Yesterday's Tractor Co.
