TractorLinks.com
Show Parts for Model:
Re: Case 430, buzzing relay, won't crank.
hondaracer2oo4
12-02-2012 12:06:32
JGardner, Thank you for the reply. I believe the tractor is about a 65. The Positive side of the battery gets grounded. The negative side goes down to the starter relay. I have found that I took the starter off of the tractor and hooked the positive side of the battery(grounded to the frame of the tractor) to the body of the starter. I connected the Negative side of the battery to the post on the starter and the starter spun fine. I tested the relay by energizing the signal side of the relay which made the relay click and gave positive continuity of the starter circuit posts. But when I hook the relay back up to the starter when it is off of the tractor it will just buzz and click click click click when you push the gear selector to start. Is it possible that the relay is failing to switch the power under a load, thus the relay is actually bad even though it will switch under no load? Would I be able to pick up a starter relay that is appropriate at an auto parts store? Thanks.
Jgarner
12-02-2012 15:17:01
 Re: Case 430, buzzing relay, won't crank. in reply to hondaracer2oo4, 12-02-2012 12:06:32
I have had pretty good luck getting tractor parts at my local NAPA. Just recently NAPA has started replacing their knowledgeable counter help with computer looker uppers and I have to explain to them what I want (had to spell Heli Coil to the lady twice). That said if you can get them to find it they do have a paper Ag and industrial catalog that helps a lot. We also have an American Standard parts store and they are pretty knowledgeable too but Pep Boys, Auto Zone, etc is worthless for tractor realted stuff. If its not an automobile that is listed in their computer they are sunk.
Try NAPA and ask for a starter solenoid, I think '65 is pre relay.
Jim
mEl
12-02-2012 12:30:47
Don't overlook a loose or corroded battery terminal or a bad connection if it has them dumb replacement cable ends on it.
mEl
