| Case Tractors Discussion Forum |
Topic: 1070 no hydralic pressure
[Return to Forum]
| Author |
[Modern View]
| MTC
12-02-2012 05:32:56
207.190.96.157
I have a 1070 which was low on hydralic fluid--no power steering,no clutch,no brakes,no PTO no nothing with engine running.The gauge on dash said no pressure.Went and filled to proper level and still no pressure.What went wrong here?? thanks |
| eldo case
12-02-2012 06:41:38
70.195.1.227
Re: 1070 no hydralic pressure in reply to MTC, 12-02-2012 05:32:56
|   If it is a yellow early model like mine this is the trouble! Need to split at the bell housing. |
| mEl
12-02-2012 06:18:18
108.10.129.188
| What year is it? On early models the pump was driven off the torque limiter plate which can fail, the spring center can go bad and the shaft driving the pump stop.
The pump also could have a complete meltdown internally. There is a suction screen on the bottom of the pto housing accessable only after removing the complete pto housing, I have seen dirty ones but it would be almost unconcievable to be plugged that completely.
Orings at the pump suction pipe, not likely but......
Although not a good thing , plugged filters will not keep oil from getting to where it belongs as there are filter bypass cartridges in each filter ( assuming its a powershift) that will open and allow unfiltered oil to go through.
Just read casecollectors post and am ammending mine in response. The fact that he lost steering and brakes also suggests a total pump failure. No steering and brake return will seriousl degrade powershifting as the steering return returns to sump through the 75 psi lube pressure regulator which operates the reverse lockout spool which has lands which also direct clutching oil flow. A powershift failure alone will not cause total system failure. However , the more info we have will help zero in on the problem.
mEl
This post was edited by mEl at 06:28:26 12/02/12. |
| casecollectorsc
12-02-2012 06:08:36
64.33.228.7
| Shift the power shift into 2nd or 3rd and watch the gauge to see if you get pressure in one of those positions. |
| Case Nutty 1660
12-02-2012 06:04:23
75.127.24.27
| pump may be air locked have seen this before especialy if pump is getting weak or suction screen is getting plugged with debris, try starting engine and wrapping throttle wide open and see if it will pick up oil, that usally will make them prime and its better than running with a airlock cnt |
| Paul A Young
12-02-2012 05:36:40
74.206.50.254
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
