TractorLinks.com
Show Parts for Model:
Re: Case 600
Rustidiot
12-01-2012 21:07:45
Thanks Tommy. Mine is complete except that someone stole the LP carb and the magneto before I could get it hauled home. I need to find those items before I can crank it. Good compression. I havent found the timing marks yet.
casecollectorsc
12-02-2012 06:16:10
 Re: Case 600 in reply to Rustidiot, 12-01-2012 21:07:45
The LP carb from a LA Case will work also. Cubic inches of the engines is real close so carb will be big enough. I've got an LA carb on a 930 rowcrop and it works great!
mEl
12-02-2012 12:25:31
 Re: Case 600 in reply to casecollectorsc, 12-02-2012 06:16:10
I have a Delco upright Mag replacer in 6 cyl if anyone can use it. Would be glad to talk.
mEl
caseman-d
12-02-2012 05:16:44
Dist or mag can be used. I have a 619 lp engine on a LA and it had a up right dist. mounted on it but some one removed the dist. I found a 6 cylinder mag from a Oliver tractor as they are more popular.
The carb. from a 900 or 930lp should work for you.
caseman-d
