Case 410 tires
BLC
New User
So looking for some help with my 1956 410 Case. The rear tires on
it are in poor shape and need replacing. Currently it has 14.9x39
6ply on there but judging by the Operators Manual it should have
either 12x38 or 13x38"s on it. How do i know what to size tire to
replace my current ones with? Will the 12x38 and 13x38 fit the
same rim and if not how do I tell which size rim I have. Sorry for all
the questions but this is my first tractor so I"m at a bit of a loss in
figuring this out and in a machine thats 58yrs old I need some
advice. Thanks!
Measure your rim width from bead to bead, that will be the info you need to determine which size tire you will need. The 400's that I've seen have been pretty evenly split between 14.9/38's and 15.5/38's. They take different rims and you never know if the tires on there are the right ones. So just measure your rim and ask where you buy your tires which size is right.
