| Case Tractors Discussion Forum |
Topic: Re: 3pt won't raise
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| 1370rod
11-26-2012 05:54:18
69.179.10.96
First remove plate under your feet in platform, looking to the rear you will see a spool protruding out the 3pt. valve with a spring over it. Now moving the 3pt. lever back and forth should cause the spool to go in and out. If it does not either the cable or the lever roll pin mentioned earlier is broken. If those items are OK and it still does not move there would be linkage disconnected in the draft control box, that is very uncommon. If everything is moving correctly the problem more than likely is a stuck spool in the control valve. Seat and its platform has to be removed to access the valve, cable, or roll pin. If valve has to be cleaned refer to a manual for its removal and disassembly. Remember durring removal, assembly and installation cleanliness is very important. There are other things inside the tractor that will cause the arms not to raise but these items mentioned are by far the most common. Rod. |
| T 970
11-26-2012 11:59:12
75.88.172.156
Re: 3pt won't raise in reply to 1370rod, 11-26-2012 05:54:18
| Should I have tractor running when I test this or not? Thank you I will get back to you it may be a week or so traveling alot this time of the year. |
| 1370rod
11-26-2012 15:59:57
69.179.10.96
Re: 3pt won't raise in reply to T 970, 11-26-2012 11:59:12
| Nope,can check that with engine off, Rod. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
