Case VAC clutch rod
DanTo
I have a Case VAC that the rod from the clutch pedal to the clutch finger bracket has been bent, broken, cut and welded. I want to make a new rod, but am not sure what the proper length should be. It is hard to measure one on another tractor as the one end is in the clutch housing. Does anyone have one of these rods that is out of the tractor that could be measured. I would like to know the length from the end that fits in the clutch finger bracket to the end of the threads (not counting the clevis on that end). Someones help would be greatly appreciated. Thank you.
I'm sure some of the guys on here has one for sale. You may have to post again. Here is one on Ebay. It's a little pricey. There may be a difference in them depending on the tractor model year?
VAC Clutch Rod on Ebay
danto,
I measured my 51 VAC clutch rod today.It is 21 1/2" long overall and the threaded part is 2" long.
Nick
