Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmers bead breaker
[Return to Forum]
m hawley
11-25-2012 09:19:01
69.182.53.154
I Know their was post not to long ago about how to change a tractor tire at that time my pc was on the fritz and I could not down load pictures. I pulled the tire off my 630 dropped it on the ground and used the axle to jack against the tire to break the bead. Make sure the key way in the axle is down and the tractor is in gear
[Reply]   [No Email]
BDT in Minnesota
11-26-2012 09:35:30
24.17.192.36
Re: Farmers bead breaker in reply to m hawley, 11-25-2012 09:19:01
Good to hear you got that tire off.. Before the next one; You might want to think about giving your Guardian Angel a raise....Appears he was working overtime..
  [Reply]  [No Email]
Hay Ride
11-26-2012 00:35:31
24.59.187.41
we use 580 backhoe.
  [Reply]  [No Email]
C. Amick
11-25-2012 19:40:48
138.210.9.42
I've seen my dad run upon the tire with the front tire of another tractor.
  [Reply]  [No Email]
farmboyWI
11-25-2012 18:20:41
50.50.151.251
Another way we learned to do it is with a hydraulic log splitter. Ours happens to be a 3-point model, I don’t know how well other types would work. Just put the splitter under the tire with a block of wood or piece of metal against the wedge on the splitter. If your hoses are long enough you can even use the same tractor to power it.
  [Reply]  [No Email]
Matt L
11-25-2012 17:47:24
50.52.23.23
I gave up on the old method of using a hammer. Its to slow and requires work.
:D I cheat and use the rear bucket on the backhoe. It takes just a min to pop the bead. I spend more time getting on and off the backhoe to flip the tires over to do the other side.
  [Reply]  [No Email]
ralph wilton
11-25-2012 14:42:45
64.127.82.36
we use a shop vac it will suck a tire down flat where a little work with a hammer the bead comes right off
  [Reply]  [No Email]
Tomfg
11-25-2012 15:16:13
206.8.13.87
Re: Farmers bead breaker in reply to ralph wilton, 11-25-2012 14:42:45
I have a rear tire to remove from a rim soon, and you've peaked my interest in the vacuum cleaner method. How do you hook up the vacuum cleaner to the valve core, and wouldn't it just suck the tube flat?
  [Reply]  [No Email]
Case Nutty 1660
11-25-2012 15:29:46
75.127.24.27
Re: Farmers bead breaker in reply to Tomfg, 11-25-2012 15:16:13
my tire guy does the same thing when pumping calcium it will pull them off the beads many times cnt
  [Reply]  [No Email]
JT
11-25-2012 09:59:39
68.53.181.110
That looks like an accident waiting to happen. It might have worked really good, but you have a tractor on a floor jack, sitting on wood blocks and using a bumper jack to push the tire, if that tire would be stubborn and not break off bead, you could lift tractor off jack, and the tractor could go anywhere, including on you or a bystander....
  [Reply]  [No Email]
Case Nutty 1660
11-25-2012 09:57:52
75.127.24.27
I have used a Handyman jack to do this on implement tires in a pinch, on 99% of my tires I cheat and call my long time tire guy to do the work call me lazy if you wnat but I figuare he is a private operator and can use the work and I am able to deduct the repairs 100% with my farm taxes so it works well for me, besides on of my jobs years ago was a tire man at the county and I really got my fill of tire repair LOL, last few I did do I used my 580's cuuting edge to break the bead worked very well great looking 630? thanks for sharing cnt
  [Reply]  [No Email]
eldo case
11-25-2012 09:44:16
70.195.0.160
I have found leaving the tire on the tractor is the easiest way to fix them. I use a old wood splitting wedge to break them down.
  [Reply]  [No Email]
tractor300
11-25-2012 09:33:34
74.36.188.25
This topic has been discussed a lot. In my opinion it is a lot easier and quicker to change them on the tractor. Just get a hand held bead breaker and a good hammer, and your set to go. Can change them in 1/4 the time.
  [Reply]  [No Email]
old
11-25-2012 09:24:10
209.86.226.34
Looks like a good way to get your self or someone else hurt. All it takes is for one of those wood blocks to fall off that floor jack and your had. By the way never good for the wood block to be on the jack the jack should be on them instead. Sorry I learned to do things the safe way and the correct way
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
