| Case Tractors Discussion Forum |
Topic: S C CONNECTING RODS
[Return to Forum]
| Author |
[Modern View]
| L.LAMP
11-23-2012 18:06:21
12.73.111.24
I was checking for bent or twisted rods by putting two rods over the same wrist pin and checking to see if the big ends made contact all the way around. I fliped the top rod over so the caps were opposite one another and observed that the distance between the wrist pin ends were closer together,about 1/8", the other way a little over 1/4". All four rods were the same. I wanted to put the rods in with the caps to the carb side so the strong part of the rod took the power stroke instead of the bolt but it appears that shouldn't be done or the rod will not be centered between the piston wrist pin bosses. I installed them per the manual. I have read here in other posts that they can be turned. I didn't want scored pistons so I stuck with the case manual. Any other views on this? I'm working on two other engines, one for a puller with M&W pistons. |
| BarryfromIA
11-24-2012 08:23:37
67.55.176.78
Re: S C CONNECTING RODS in reply to L.LAMP, 11-23-2012 18:06:21
| Back in the day, Dad had an SC that he overhauled with bigger sleeves and pistons and a bigger carburetor. He pulled a 3-14 CASE plow with it. |
| Kly
11-24-2012 08:03:42
64.147.46.106
| | early SC had 3/12 bore late SC's have 3 5/8 with a larger carb. A late SC will handle a 3 btm plow or almost any implement that a early DC will pull. |
| tomturkey
11-24-2012 07:58:57
216.81.211.253
| Don't misunderstand me please, I really enjoy my SC, It has cleaned snow, bushhoged pasture, run the sickle mower in the hay field, pulled the rake. Its getting tired, actually it was probably tired when I bought it. Before I put new working clothes on her, I need to address these engine issues. gobble |
| tomturkey
11-23-2012 19:50:54
216.81.211.253
| What all did you do to your SC engine? My 52 SC smokes and is lacking in power. I understand they were never a power house and won't be. I've never done a compression test on it. Am wondering what you did and what you used for rings etc. gobble |
| L.LAMP
11-24-2012 08:05:26
12.73.110.173
Re: S C CONNECTING RODS in reply to tomturkey, 11-23-2012 19:50:54
| You can bore out the sleeves of your '52 SC to 3 11/16" and put in button top pistons with a 5617 head in good shape along with the late model carb and you should be good for 37 hp. I have two '54's that have button top pistons with 3 5/8" bore that turn 32hp on the dino at 540pto rpm. The first time I pulled my '44 SC after rebuilding the head it powered out in 4500 class and had motor to spare. It is 3 11/16" bore. It carrys the front wheels. I use Hastings piston rings. I'm working to get 42-45 hp from an SC engine with modified factory parts. |
| dboll
11-24-2012 06:44:16
209.23.168.240
| I guess I don't understand why everyone thinks an sc is such a dog, Dad had a farm with lighter ground in the early 60's where he pulled 3-14's with one in 2nd and in the heavier clay loams an sc would pull 2-16's while an M or dc pulled 3-14 or 3-16 |
| wilson ind
11-24-2012 07:05:15
70.239.85.115
Re: S C CONNECTING RODS in reply to dboll, 11-24-2012 06:44:16
| you must have got the pit-bull of the sc family. my sc was the small beagle. just followed the dc with it's nose. |
| dboll
11-24-2012 08:56:35
209.23.168.146
Re: S C CONNECTING RODS in reply to wilson ind, 11-24-2012 07:05:15
| I like the sc for light farm and yard work. Just a nice little handy tractor that is much easier to drive and less ackward than a dc. That and the fact that they practially make gasoline. |
| wilson ind
11-24-2012 13:26:45
70.239.85.115
Re: S C CONNECTING RODS in reply to dboll, 11-24-2012 08:56:35
| I have seen SC's at tractor pulls that were very strong older fellow had it stock as he had not worked on it. Others would power out almost to embarras the owner. I have always wonndered if the timming gears were all cut with keyway the same. Should have pulled front cover on mine and tried different teeth. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
