1st dad-in-law passed away,2nd losing job. 3rd annual thanksgiving day grandkid tractor ride was short!!! as the 630D started to push water out the rad. cap that was the "last straw" I lost it in front of the kids! they took off for the house I to the barn. No it didn't overheat shut it off refilled it. Started it and it bubbled out. I have had it,I'am ready to push the dam thing out and sell it! So before I do whata all think is wrong? waterpump or worse?
Bubbles in the radiator mean either head gasket or cracks. Hopefully gaskets. Sorry about the poor luck around the holiday. I would pull the head before pushing it out the door.
Gregg,
Chances are that it is a head gasket, how ever it could be an injector liner or a cracked head. When I got my 430, I could not keep the coolant out of the pan. Started tearing it down, as it had a Vocational Ag School overhaul done on it, and I found that they ruined the Timing gear gasket where the head buts up to it. I know that isn't likely your problem, but be sure to remove the water pump AND the hollow 5/8" bolt behind the water pump when you pull the head.
Hope things get better for you, and maybe you can get the grandkids involved with the fix. Might be time well spent by all of you.
Loren
Sorry about your bad luck.
Is it just pushing anti-freeze out or making bubbles?Could it be the thermostat stuck or the bottom radiator hose collapsing?
Nick
Sorry to hear of the bad luck, sure hope things turn around now. Bubbles in rad. more than likely as the guys said head gas. or possible cracked head, will keep fingers crossed for the simple fix. Knew you your POed, you always sign off with God Bless which I liked. Hope this helps, God Bless, Rod.
hang in there , you can handle it ,, keep it together man , especially around those that luv ya,, hope you don't have to learn the hard way , like i did , you need sumthin to start working for you ,,prayer helps , a good secure job will definately help , as for the 188/630.more than likely head gasket..bars leak will make it go away for a decent sale ,,fyi . i fed my 430 /188 bars leak for a yr,and got by doing daily runner stuff before we finaly took it down ,only because the clutch was plumb shot ,had serveral bad valves ,and the dual steering cylandars were in a need for seals, and the 3 pt was drip in oil in the rear end .. when that fella came out of the shop 3 weeks later it was parade ready .that was 2007 .It STIL IS Parade ready
Sorry to hear about your bad luck...had a good friend get me thru a bad time in my life. Told me "Good times dont last forever...Bad times don't either". Hang in there...Head Gaskets can be replaced so can engines..Family Hell of a lot harder!!!
may only be a head gasket ,could be cracked head.if i was closer to you i would come over and help you repair it
